Gracias por tu ayuda pero fijate que ya busque y busque dentro de todos los archivos y no lo encuentros.. segun este archivo tiene el fallo
mysql.class
<?php
* Advanced Guestbook 2.4.3 (PHP/MySQL)
* Copyright (c) Chi Kien Uong
* URL: http://www.proxy2.de
class gbook_sql {
var $conn_id;
var $result;
var $record;
var $db = array();
var $port;
function gbook_sql() {
global $GB_DB;
$this->db = &$GB_DB;
if(ereg(":",$this->db['host'])) {
list($host,$port) = explode(":",$this->db['host']);
$this->port = $port;
} else {
$this->port = 3306;
function connect() {
$this->conn_id = mysql_connect($this->db['host'].":".$this->port,$this->db['user'],$this->db['pass']);
if ($this->conn_id == 0) {
$this->sql_error("Connection Error");
if (!mysql_select_db($this->db['dbName'], $this->conn_id)) {
$this->sql_error("Database Error");
return $this->conn_id;
function query($query_string) {
$this->result = mysql_query($query_string,$this->conn_id);
if (!$this->result) {
$this->sql_error("Query Error");
return $this->result;
function fetch_array($query_id) {
$this->record = mysql_fetch_array($query_id,MYSQL_ASSOC);
return $this->record;
function num_rows($query_id) {
return ($query_id) ? mysql_num_rows($query_id) : 0;
function num_fields($query_id) {
return ($query_id) ? mysql_num_fields($query_id) : 0;
function free_result($query_id) {
return mysql_free_result($query_id);
function affected_rows() {
return mysql_affected_rows($this->conn_id);
function close_db() {
if($this->conn_id) {
return mysql_close($this->conn_id);
} else {
return false;
function sql_error($message) {
global $TEC_MAIL;
$description = mysql_error();
$number = mysql_errno();
$error ="MySQL Error : $message\n";
$error.="Error Number: $number $description\n";
$error.="Date : ".date("D, F j, Y H:i:s")."\n";
$error.="IP : ".getenv("REMOTE_ADDR")."\n";
$error.="Browser : ".getenv("HTTP_USER_AGENT")."\n";
$error.="Referer : ".getenv("HTTP_REFERER")."\n";
$error.="PHP Version : ".PHP_VERSION."\n";
$error.="OS : ".PHP_OS."\n";
$error.="Server : ".getenv("SERVER_SOFTWARE")."\n";
$error.="Server Name : ".getenv("SERVER_NAME")."\n";
echo "<b><font size=4 face=Arial>$message</font></b><hr>";
echo "<pre>$error</pre>";
if (eregi("^[_a-z0-9-]+(\\.[_a-z0-9-]+)*@([0-9a-z][0-9a-z-]*[0-9a-z]\\.)+[a-z]{2,5}$", $TEC_MAIL) ) {
$headers = "From: $TEC_MAIL\r\nX-Mailer: Advanced Guestbook 2";
// @mail("$TEC_MAIL","Guestbook - Error","$error","$headers");
exit();
donde debo poner la db manualmente
