Autor Tema: MONTANDO UN "CIRCUMVENTOR" SITE [NECESITO AYUDA]  (Leído 6777 veces)
« : julio 27, 2006, 10:13:00 am »
pues kiero traerles esta peticion a los web master de por aki, mi peticion es para ke alguien se anime a montar un site "circumventor"
tomado de wikipedia ingles:
A circumventor is a web-based page that takes a site that is blocked and "circumvents" it through to an unblocked website, allowing the user to view blocked pages. A famous example is 'elgoog', which allowed users in China to use Google after it had been blocked there. Elgoog differs from most circumventors in that it circumvents only one block.
The most common use is in schools, many blocking programs block circumventors as loopholes, only by site not by code. That means that every now and then someone can get around it. Circumventors are also used by people who have been blocked from a website.
The use of circumventors is usually safe with the exception that circumventor sites run by an untrusted third party can be run with hidden intentions, such as collecting personal information, and as a result users are typically advised against running personal data such as credit card numbers or passwords through a circumventor.
en resumidas es un site ke te ayuda a pasar los filtros en las empresas y eskuelas, seria chivo ke el svcommunity tuviera el suyo propio, lo malo es ke komo en el kaso de realbo, no puede entrar a los ke ya estan hecho o disponibles porke los mismo sitios ke son para acceder a sitios desblokeados ya estan blokeados... la idea seria montar el nuestro propio y editarle el texto ke trae en la pajina principal por algo "inofensivo" ke burle el filtro. un ejemplo de sitios circumventors son:
http://www.ChemistryNerds.com/
https://www.K12AudioBooks.com/los dos anteriores estan blokeados para mi, el siguiente es el ke uso para entrar al foro (porke el foro de svcommunity.org esta banneado por el filtro de DELL (ke es donde yo trabajo y ahi usan el programa SMARTFILTER para el blokeo))
https://www.PreBuiltServers.com/
asi ke la idea seria tener uno propio komo esos, lo uniko ke se necesita es una makina encendida todo el tiempo e instalar el kodigo ahi, las instrucciones komo hacerlo estan aki:
http://peacefire.org/circumventor/simple-circumventor-instructions.html
Desconectado realbo
Re: MONTANDO UN "CIRCUMVENTOR" SITE [NECESITO AYUDA]
« Respuesta #1 : julio 27, 2006, 02:03:35 pm »
narutin probe en mi trabajo entrar con
a sitios blokeados y si me furulo p$$ta te pelaste gracias brother  :thumbsup:
estaria interesante llevar el proyecto de naruto a una realidad de mi parte brother demosle tenes mi apoyo y la gente que quiera apoyar la inciativa demosle
« Última Modificación: julio 27, 2006, 02:07:08 pm por realbo »
« Respuesta #2 : julio 27, 2006, 02:32:45 pm »
hey es cierto el llamado es para los WEBMASTERs los ke se las saben de todas todas kon lo de los sitios de internet, komo el "rdoggsv" o el sr "mxgxw" aun el amigo "chero07" komo ke tiene una onda de hosting o no se kien era el de eso, pero tambien necesito asesoria, porke segun las instrucciones korre en windows y komo ke esta dise#ado komo para no estar alojado en un site, komo les digo, no se bien komo funciona, ahi dice ke lo instales en la PC de tu kasa y ya.... eso es todo.
 APOLLEMOS ESTA INICIATIVA.... no solo nos va a veneficiar a los ke tenemos filtro, si no ke a mucha mas gente ke necesita usar un proxy o ke simplemente algun software le blokea el accesso al la libre informacion
Desconectado rdoggsv
« Respuesta #3 : julio 27, 2006, 02:40:13 pm »
Lo siento naruto pero si no me das una maquina en donde instalar esto no te puedo ayudar , tu idea es buena pero para tu buena idea se necesita una maquina en donde esto este instalado , yo no cuento con esto para ofrecertelo. Por el momento hay varios otros sitios que te permiten usar el circumventor y no veo porque la prisa de tener uno propio.
Es cierto que ahorita tengo a la mano el servidor en el que esta alojado el foro pero es una maquina pequeña que cuenta con 256M de ram y como 1G de procesador, no se si te has dado cuenta pero esta haciendo esfuerzo en mantener el foro activo ahorita que estamos alcanzando por lo menos unos 50 usuarios registrados y unos 50 invitados navegando al mismo tiempo,y estoy pensando en agregarle mas RAM, por lo que no te puedo ofrecer en sobrecargar mas el server con algo que no siento sea necesario.  :thumbsup: :)
« Respuesta #4 : julio 27, 2006, 02:51:41 pm »
no puesi, eske solo era una peticion, si no se puede no pues, no pasa nada, talvez para vos no es necesario, ustedes pueden acceder todo lo ke kieran, en kambio realbo y yo no, solo pediamos ayuda, se ke tenes un site o mas ke mantener, obviamente no es de vida o muerte, pero este fue el primer lugar donde se me okurrio pedira ayuda, pero si no se puede pues gracias de todos modos, muy bonito tu foro, te felicito
« Respuesta #5 : julio 27, 2006, 02:58:48 pm »
como me podes decir que vos o que realbo no pueden accesar al foro si aqui estas escribiendo y de realbo nunca he visto que se queje que no puede accesar ??? cuando yo mismo he pasado tratando de buscarte los proxys que tengan circumventor para que cuando te quejabas que no te podias conectar te conectaras ??
si simplemente veo que estas por todos lados exigiendo que haga algo al respecto de instalar un circumventor y te contesto que en este momento no cuento con el equipo para instalarlo que queres que haga man ??? lo instalo en el server aun cuando se que lo va a saturar y se va a sacrificar la funcionalidad del foro por tener un software que se puede encontrar en otro sitios ??
muy bonito tu sarcasmo te felicito  :thumbsup:
Desconectado realbo
« Respuesta #6 : julio 27, 2006, 03:04:13 pm »
vaya vaya trankilos  :ko: yo si puedo accesar al foro pero hay mucccccccccccccccccccchos otros sitios a los que no puedo entrar solo puedo entrar con esta onda ke me dio narutos al fin hace algo bueno jaja hagarrenla al suave ke todo tiene solucion menos la muerte
« Respuesta #7 : julio 27, 2006, 03:06:59 pm »
man si no creo que ninguno de nosotros este enojado , yo siento que he contestado de una manera pacifica y tranquilo  :thumbsup: , pero en realidad no tengo una maquina para instalarlo entonces no puedo ayudar en esto , simplemente eso le hice ver a naruto y contesto de una manera bien particular.
No creo que sea solo yo el que siento que el foro esta lento y esto es debido a la escacez de ram con la que se cuenta.  :thumbsup: No me puedo poner a instalarle otros softwares que lo van a sobrecargar mas todavia  :sur:
Desconectado estudio82
« Respuesta #8 : julio 27, 2006, 03:14:39 pm »
hey rdoggsv como podemos hacer para hecharte la mano y ayudar al foro, digo para agregarle mas ram a la makinilla, estoy dispuesto a hecharte la mano... creo k algunos komuniters te podemos ayudar...
« Respuesta #9 : julio 27, 2006, 03:33:13 pm »
:offtopic:  ese komentario no va aki, mandale un MP si le keres proponer algo, sorry si salgo asi pero es para mantener el orden, yo esperaba leer algo sobre este tema aki, sorry por el komentario, si no leete las reglas del foro :offtopic:
siguiendo kon lo del tema, o alguien ke tenga un ciber ke nos pueda hechar la mano, instalarlo en un par de makinas en un ciber, igual pasan todo el tiempo encendidas y de dia es ke lo usariamos... si no necesito ideas, un pokito de apoyo aunkesea
« Respuesta #10 : julio 27, 2006, 03:47:18 pm »
lo mencione aki viejito pork no encontre la lista de usuarios conectados asi k no le mande un privado a rdoggsv pero kreo k te estoy ayudando en todo kaso y claro k va con el tema viejo si te extendes y pensas un pokito mas si tiene k ver. Mi huminde opinion kerido y apreciado naruto
Desconectado fermarroquin
    • Fernando Marroquín
« Respuesta #11 : agosto 24, 2006, 08:14:08 pm »
NO siento que seá necesario.
Desconectado Astro
  • Führer Irken
« Respuesta #12 : agosto 24, 2006, 08:54:50 pm »
Mira viejo talvez para vos no es necesario .... pero para algunos como los simples mortales si, debido a que nuestro internet estan baneados varios sitios y esta es la unica forma de estar en linea.
Mira tengo que aceptar naruto, un usuario no deseado por muchos pero esta onda que puso por los menos los links han servido a mas de alguno incluso a mí.
« Respuesta #13 : agosto 29, 2006, 03:13:12 pm »
a mi tambien me han servido un resto...
por que navego solo desde el trabajo y estoy tras un proxy... hay muchas cosas que no puedo hacer pero esto me esta ayudando desde que lo publique hice mis busquedas y encontre algunos y funkan...
por cierto el buscador del foro no encuentra nada  :cry: me costo encontrar este tema de nuevo
