Author Topic: De cuál cable HDMI debería comprar ??? [ENG]  (Read 21777 times)
Offline obser7er
  • ferg(at)pcpimpz.com
« on: October 25, 2010, 10:32:22 pm »
Para que no les den paja ni en las tiendas de electrodomésticos ni en el agachón:
En términos generales cualquier cable HDMI sirve para lo mismo, y la calidad no debería de variar sólo porque vale $50.00+ y porque dice que es mejor que los cables baratos... obviamente lo que si puede variar es la durabilidad del mismo, pero después de todo quien va a estar moviendo a cada rato su monitor/TV LCD/LED/PLASMA:
Let's cut to the chase:
CNET strongly recommends cheap HDMI cables widely available from online retailers instead of the expensive counterparts sold in your local electronics store.
Here's why:
Expensive cables aren't worth it
If you walk into your typical electronics store to buy an HDMI cable, you're likely to see prices upward of $50 with promises of better performance and faster speeds. Do you really need to spend that much money on a single HDMI cable?
Absolutely not--those cables are a rip-off. You should never pay more than $10 for a standard six-foot HDMI cable. And despite what salesmen and manufacturers might tell you, there's no meaningful difference between the $10 cable and the $50 cable. Unless you see something obvious, such as dropouts or a flashing screen, the digital information transmitted by both cables is exactly the same--no cable can make the picture any better or any worse. We've used cables from many different companies in the past--such as Belkin, Accell, Monoprice, Monster, and SimplayHD--and have not run into any consistent issues with any brand of cable. With working cables and solid connections, we've seen no dropouts and "sparklies"--just consistent, dependable, high-quality audio and video. It's that simple.
Even a heavy-duty, high-end Monoprice cable cost us less than $20. But feel free to buy a cheaper one for a standard home theater.
The editors at CNET are so confident that cheap HDMI cables offer identical performance, we've been using inexpensive Monoprice HDMI cables in the CNET Home Theater Lab for more than a year with no issues. That's saying a lot, especially when you consider that our video experts are constantly swapping in new products and changing configurations, which means our cables take much more abuse than they would in a normal home theater. We're also accustomed to making long cable runs, and many of our cables from Monoprice are 15 feet long. We also use even longer 20-foot cables from a generic maker with no appreciable loss in video quality. If cheap HDMI cables are good enough for the eagle-eyed video professionals at CNET, we're betting they're good enough for your home theater.
And don't get hung about other cables that offer a lifetime guarantee, protecting you in case your cables are technologically obsolete in the future. If in a few years there are consumer video products that output higher-than-1080p video signals (an admittedly unlikely scenario), you can always buy another cheap $10 cable online that can handle more data. And you've still saved yourself $30 over that $50 cable in the store.
Cheap HDMI cables sound great! Where can I get them?
The best way to score a cheap HDMI cable is to order over the Internet. Here are a few of our favorite resellers, all of which offer solid return policies in case you do get a bum cable.
Monoprice.com sells all other kinds of quality AV cables at very reasonable prices. As we mentioned before, we use Monoprice cables in CNET Labs, and several CNET editors use Monoprice in their personal home theaters as well.
Amazon is especially convenient if you're already buying electronics from them and just want to "add to cart" an HDMI cable. We've done hands-on testing with a $2.10 HDMI cable from DVI Gear and haven't had any issues. Return policies vary by reseller, however, so do your research first.
Newegg.com, another online retailer with whom CNET editors have had good experiences, has several HDMI cables for less than $10.
CNET itself lists numerous inexpensive cables as search results for the term "hdmi cable"--as long as you sort the results properly (lowest price first). Again, return policies vary by reseller.
Fuente:
http://reviews.cnet.com/hdmi-cable/
info: ferg(at)pcpimpz.com
GerardB
Re: De cuál cable HDMI debería comprar ??? [ENG]
« Reply #1 on: October 25, 2010, 10:35:31 pm »
Buen aporte, a mas de alguno le va a servir.   :thumbsup:
A mucha gente la estafan de esa manera  x_x
Lo unico es que, si vas a usar un cable HDMI SUPER DUPER MEGA LARGO, si vale la pena usar uno de mejor marca.
Eso lo escuche en "HDnation", programa de Revision3.
Offline Clive Barker
  • A Deeper Silence ever-
    • HightPerfomance (Ventas)
« Reply #2 on: October 25, 2010, 10:59:09 pm »
Para mi es cierto en el sentido que es absurdo pagar hasta $100.00 dolares por un Monster pero tampoco se puede decir que cables de $5 dolares genéricos rendiran en tiempo y calidad que marcas intermedias- A´apoyo la noción principal pero tampoco es que cualquier HDMI funcionara adecuadamente. Y claro entre más largo más caro-- lo leere detenidamente pero no es que todo lo caro es malo y lo barato se asemeja a lo caro.
Offline Distante
« Reply #3 on: October 25, 2010, 11:08:53 pm »
Yo tengo un cable hdmi como de 3 metros  :rofl: y es genérico, la verdad no me ha dado ningun inconveniente, por cierto lo compre en casa rivas XD
« Reply #4 on: October 25, 2010, 11:10:06 pm »
Cuanto tiempo lo llevas usando?
Offline Distante
« Reply #5 on: October 25, 2010, 11:12:32 pm »
Un poco mas de 2 meses sino me equivoco, creo que mientras no sufra maltrato o este en una zona húmeda o caliente durará mucho  :thumbsup: aunque yo era de la idea que un cable hdmi de marca tenia mejor calidad de imagen y audio pero al parecer como que eso es algo relativo
mored
« Reply #6 on: October 25, 2010, 11:45:16 pm »
Buen topic...como siempre eh dicho "en la calle encontras las mismas cosas,solo que duran menos"
DarkLord
« Reply #7 on: October 26, 2010, 09:06:01 am »
Buen post pero para la gente normal como nosotros que solo tiene pantallas planas entre 22 a 52 pulgadas y monitores de los estandard de 19 a 32 ya que nosotros solo movemos imagenes normales de video, pero para la mara que mueve resoluciones de formato de cine ya sea en 2k y 4k
seguramente a ellos nos les va a doler pagar por cables HDMI arriba de 100 o 200 dolares ya que ahi si se necesita un cable con mejores aspectos como los que venden en tigerdirect o newegg
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6076036&CatId=5954
http://www.newegg.com/Product/Product.aspx?Item=N82E16882155283&cm_re=hdmi_cable-_-82-155-283-_-Product
Pero claro ellos porque si necesitan un mejor cable HDMI nosotros que movemos imagenes normales pues ya bien lo dijo Distante no necesitamos pagar mucho por un cable HDMI para nuestro monitor o pantalla plana  :thumbsup: buen post
Offline mxgxw
« Reply #8 on: October 26, 2010, 09:44:35 am »
Son señales digitales. Un cable barato contra un cable de $200 mientras ambos cumplan la certificacion HDMI no habrá diferencia.
Lo que pasa es que a la mara se la timan XD...
Offline vlad
« Reply #9 on: October 26, 2010, 10:23:34 am »
Casi un año con un cable HDMI de $3.50 del Hiper Paiz y ahi sigue , sonido y video +AAA :yahoo:
Offline Hey-man
  • WTF
« Reply #10 on: October 26, 2010, 12:42:11 pm »
lol si tenes uno de 52 inch para arriba si tenes el $$ para comprartelo no creo que te duela comprarte un cable de unos miserables $100
People say things digitally that they would never say in a face to face conversation
Offline mxgxw
« Reply #11 on: October 26, 2010, 12:44:11 pm »
 :rofl: Esque hay mara que piensan que porque ven el cable que es mas grueso pasan mas datos fksajd haskjfhkfjsa
Offline RedSteal
« Reply #12 on: October 26, 2010, 12:52:04 pm »
Con mi cable del hiper paiz y todo tranquilo (viendo hdmi en una lcd 32"). Ahhh,si buena calidad me salieron esos cables :p (aprovechen mara,tan al 75%,que nadie les hace caso?).
Y agrego mas info para el que quiera mas info grafica:
xD
« Reply #13 on: October 26, 2010, 01:09:51 pm »
Ese pensamiento es bien POMA  :rofl:
Sigo creyendo que algunos comentarios no son representativos es decir si de 100 que tienen HDTV/LCD 3 dicen que con cables de $4 están felices y para variar los tienen hace no mucho. Cuando yo estuve vendiendo unos cables HDMI todos los que me los compraron se quejaron que la calidad de esos cables era pésima ni UNO me dijo ni siquiera que eran regulares. Todos dijieron que la calidad rondaba lo pobre, entonces no puedo creer que todos sean buenos por más bajeros que sean, Tarde o temprano se van joder XD
x2
Offline obser7er
« Reply #14 on: October 26, 2010, 01:41:04 pm »
Sigo creyendo que algunos comentarios no son representativos es decir si de 100 que tienen HDTV/LCD 3 dicen que con cables de $4 están felices y para variar los tienen hace no mucho. Cuando yo estuve vendiendo unos cables HDMI todos los que me los compraron se quejaron que la calidad de esos cables era pésima ni UNO me dijo ni siquiera que eran regulares. Todos dijieron que la calidad rondaba lo pobre, entonces no puedo creer que todos sean buenos por más bajeros que sean...
No somos nosotros los que lo afirmamos tajantemente, lo asegura la gente de CNET:
