Author Topic: Mis Primeros Pasos en Audio del PC (X-fi , Audigy y demas)  (Read 25208 times)
Offline netss
  • Net$$...
Re: Mis Primeros Pasos en Audio del PC (X-fi , Audigy y demas)
« Reply #30 on: August 14, 2007, 01:30:21 pm »
mmm.. JED57.. tal perece que vos deducis antes de investigar.. la x-fi xtreme no es la mejor tarjeta de sonido de echo es gama baja.. pero acomodado con las bocinitas gigaworks.. esta bastante decente..
Offline JED57
« Reply #31 on: August 14, 2007, 02:24:31 pm »
Bueno ese es el punto Netts la Xfi xtreme cuesta unos $40 dolares en el mercado americano la cual es basicamente una audigi SE lavada de cara y con otro nombre y que la venden mas cara, ese es el punto, y con ese dinero mejor te compras una audigy 2 zs usada, con la cual tiene un mejor chip y mejores componentes. la xfi xtreme no tiene el chip:
cito nuevamente DE WIKIPEDIA: (pero hay muchas fuentes mas que lo confirman)
X-Fi Xtreme Audio
The entry-level model of the X-Fi series, the Sound Blaster X-Fi Xtreme Audio, does not actually have the EMU20K1 chip but is a re-branded Audigy SE, using the same family of chips (CA0106-WBTLF), and even the same drivers[2]. Thus, not only is all of the X-Fi–related processing performed in software, but it also lacks basic hardware acceleration just the like SB Live! 24 bit, the Audigy SE and other budget Soundblaster models. The X-Fi Xtreme Audio does not use the same drivers as the rest of the X-Fi family, some games do not recognize it as being "X-Fi capable hardware", and the device's hardware profile resembles that of older Live! and Audigy cards. Furthermore, users have reported that it slows down some applications and games [8][9][10]. Thus, even if the card is marketed as part of the X-Fi line, it does not belong to it technically, just like the Audigy SE doesn't technically belong to the Sound Blaster Audigy series. The card is not marketed as supporting the "X-Fi Gaming Mode", and there are no official implicit or explicit statements regarding its having hardware acceleration or not.
eso tecnicamente dice que la xtreme no es una xfi sino que es una Audigy SE renombrada, por cierto a audigy SE todavia no le llega ni a los talones a una Audigy 2 zs mucho menos a la 4
Conclusion cualquier tarjeta de sonido creative le patea el ass, a el basura codec realtek qeu tengas en tu mobo
si quieres buen sonido a buen precio, comprate una Audigy 2 zs o 4pro usada
si quieres irte por la segura comprate una audigy SE, no es tan buena pero es barata
si te sobra el dinero comprate la barracuda...
http://www.razerzone.com/index.php?main_page=product_info&products_id=41
Offline netss
  • Net$$...
« Reply #32 on: August 14, 2007, 02:26:10 pm »
aahahaha gracias JED...
Offline JED57
« Reply #33 on: August 14, 2007, 04:16:35 pm »
[IRONIC MODE ENABLED]??? Netss¿¿??
Offline Jarthur
  • SVC Old Member.
« Reply #34 on: August 15, 2007, 08:26:40 am »
si yo quisiera gastar como $70.00 en una tarjeta de sonido mi eleccion seria por una X-Fi XtremeMusic, es de los primeros cuatro modelos que lanzo Creative originalmente y cuenta con todas las caracteristicas excepto que no lleva los 64 MB de Xram (trae 2 MB) y viene sin el panel frontal, (y los LED que iluminan un letrero X-Fi quqe vienen en los modelos mas Elite y Fatality).
cumple THX, DTS, Dolby EX, EAX HD 5.0, Apon AL,  hace todas sus funciones en hardware.
(bueno esa es la tarjeta que uso).
digo, se podria comprar algo que cueste menos pero se pierde muchas funciones.
por otro lado si van a pedir por internet la tarjetona que pusiste esta mejor que todas las nombradas.
Tech Chat SV Community.
Offline JED57
« Reply #35 on: August 15, 2007, 08:37:59 am »
Hey Jartur que parlates usas con tu X-fi?
Offline Jarthur
  • SVC Old Member.
« Reply #36 on: August 15, 2007, 07:08:40 pm »
unas Altec Lansing 621. (2.1) (140 watts RMS segun panfleto del fabricante, serian como 1000 watts pmpo)
pero ya va siendo hora de buscar reemplazo, por eso mencione las Logitech Z, como nota personal no me gustan los set de bocinas, porque se me hace estorboso, por eso solo busco estereo, pero la verdad ya me estoy picando se hacer uso de todos esos canales que no uso.
quien quita un dia me compre unas Cambridge 7.1 , pero cuando me sobren los $$ que me va a costar, alla tipo 2009.
lo mejor esta por venir, awebo.
« Last Edit: August 16, 2007, 05:46:19 pm by Jarthur »
Offline JED57
« Reply #37 on: August 16, 2007, 10:00:39 am »
mmm Creo que ire a probar unas Z... no se que tan baratas se consegiran????
Offline Jarthur
  • SVC Old Member.
« Reply #38 on: August 16, 2007, 06:01:03 pm »
Logitech Z5500 $400.00 precio local, no hay stock. (please, insert commercial here)
Sonido superior
Así suena lo más alto de la gama.
    * Descodificación digital 5.1 integrada: Hasta el más mínimo detalle de sus bandas sonoras Dolby® digital y DTS favoritas.
    * Sonido con certificación THX: No se conforme con menos y exija el sello de garantía THX para disfrutar de una calidad de copia maestra.
    * 505 vatios: Cualquier habitación de la casa se convierte en una espectacular sala de cine.
    * Subwoofer de carrera larga de 25,4 cm y puerto de graves optimizado: 188 vatios de graves potentes y sin distorsión.
    * Bocinas satélite con corrector de fase de aluminio pulido: La claridad del tweeter combinada con la intensidad de la gama de medios independiente.
No me esperaba que fueran tan caras.
Offline obser7er
  • ferg(at)pcpimpz.com
« Reply #39 on: August 16, 2007, 06:59:04 pm »
Que opinan de ésto para comenzar, es decir para olvidarme del RT GENIUS 5.1 CHANNEL PCI
Key features:
Soporta audio posicinal en 4/6 CH en modo de altavoz
Soporta música directa y aceleracíon de hardware de sonido directo
Puerotos de juegos duales de alto rendimiento
Interfaz MPU401 compatible MIDI
Reproducción de códec de 16-bit y grabación
Compatible con Sound Blaster, Sound Blaster Pro y Microsoft DirectSound
Aplicaciones de software incluidos Audio Rack y WinRip
Cumple con especificaciones MicrosoftR PC99
Utilidades DirectX 8.0 incluido
Sé que no es la gran cosa pero por un precio $<15 me gustaría saber que tan buena o mal es???
info: ferg(at)pcpimpz.com
Offline JED57
« Reply #40 on: August 16, 2007, 08:12:00 pm »
Justamente vi el precio de las logitec z el dia de ayer por la noche y me fui de espaldas $300 en el mercado americano... creo que en realidad estan un poco sobrevaloradas  :shock:
Aunqeu la verdad lucen muy bien muy bien
en fin creo que me quedo con las klipsh 2.1 que tienen muy buenos comentarios y cuestan mucho menos unos $170
Con respecto  la genuis casualmente el dia de ayer tambien la pude ver esa tarjeta en particular la cual tiene un Codec Cmedia de la serie 87xx, el cual considero que a lo sumo es un poco mejor que el que traia la mitica PCSHITS m748lmrt
En fin una opcion si no tienes sonido; mejora desde el integrado lo dudo, creo que es botar el dinero, mejor vete por aunqeu sea una audigy se
saludos
Offline Jarthur
  • SVC Old Member.
« Reply #41 on: August 17, 2007, 08:27:13 am »
saludos
X2
tambien podria optar por una Live 24.
entonces vas a por las Klipsh; no va a ver regazon de cables alrededor de tu escritorio.
Offline Tino
« Reply #42 on: August 17, 2007, 09:05:37 am »
Sonido superior
Cuando veo estas ondas solo quisiera tener cuarto disponible en mi casa (y $$$ tambien) para tener un sistema home theater en mi casa, siempre me ha enculado el sonido dolby de los cines.
Offline Jarthur
  • SVC Old Member.
« Reply #43 on: August 17, 2007, 10:44:50 pm »
en amazon hay que tener cuidado, manejan productos que son de terceras empresas y a veces ofrecen un producto y te entregan otro, y no hay cambio ni reembolso.
Solo hay que ver los comentarios de la gente que ha comprado ese producto, normalmente son buenas opiniones pero tambien las hay malas.
termino el off-topic.
las Z5300 me parecen un buen equipo, vere la web de Logitech a ver que prestaciones ofrecen.
Offline JED57
« Reply #44 on: August 17, 2007, 11:39:00 pm »
Cheken esta pagina:
http://www.logitech.com/index.cfm/speakers_audio/home_pc_speakers/&cl=us,en
Precio sujerido de los z5500 $400
Precio sujerido de los z5300 $200
Bueno a $150 estan baratos pero tampoco es demaciado lejos del sujerido...
bueno en realidad los z5500, es la vercion de super lujo y se ha de notar en las terminaciones y en detalles asi como calidad de materiales y como toda gama alta, el jugoso margen del fabricante
