Autor Tema: Teclado Con Luz (Donde hay de esos? aki en E.S.)  (Leído 7632 veces)
Desconectado hackstar
  • HACKSTAR ®
    • COMPRANDO BARATO
« : agosto 25, 2006, 12:09:26 pm »
Bueno estos dias andaba en busca de un teclado pa alucinar mi escritorio con un teclado chido y encontre esto:
Sunbeam EL-KB-03-SV Silver Multi-Media Lite-up Keyboard
Quantity in Basket:none
Code: 4161SV
Regular Price: $19.99
Our Price: $17.99
Stock: IN STOCK
Silver Keyboard with blue lighting
Blue electroluminescent lighting with clear keys
Includes an ON/OFF button for the keyboard light!
107 Key Layout including numeric keypad and hot keys
Multi-media Hot Keys for internet, email, sound, calculator and more
Slim ergonomic design
Fully compatible with PS/2
Works with: Window$ 95/98/2000/XP/NT/ME
Lighting is suited for dim-light to no-light applications
Power management with the ACPI keys
  Interface IBM PS/2
Operation System Window$ 98/ ME /2000/ XP / NT or above
Mechanical Data Total travel (mm) 4.0 ± 0.5 mm
Travel to peak (mm) Peak force (g) 1.5 ± 0.5 mm
55 ± 10 gm
Switch life 5 million life cycles
Weight (g) 0.54 kg
Dimension (mm) 46 x 18 x 3.25 cm
Electrical Datas Supply voltage and current + 5VDC ± 5%@100 mA
Environment
Conditions
Agency approvals FC CE
Operating temp 0~55 ° C
Storage temp -20 ~ 65 ° C
Operating humidity 10% + 95% RH
« Última Modificación: agosto 27, 2006, 01:42:35 am por Mad Max »
  • HACKSTAR ®
    • COMPRANDO BARATO
Re: Telado Con Luz (Donde hay de esos? aki en E.S.)
« Respuesta #1 : agosto 25, 2006, 12:14:33 pm »
Y tambien este otro:
Logisys Phone Smart LED Keyboard
Code: 4155BK
Our Price: $15.99
Stock: IN STOCK
The Logisys Phone Smart LED Keyboard KB801BK is a very bright backlit keyboard. Each and every key on the board has a blue LED underneath for ultra bright effects, allowing uesers to work in an entirely darkened room. Should the user wish to turn the LEDs off, no problem - there is an on/off switch. Logisys has built a cell phone sensor into the keyboard, which activates the numeric pad's LEDs, should your cell phone ring. This function could be useful for users who are hearing-impaired, users in meetings, or simply users who are annoyed by their own ring-tone.
Aqui el video con el "Led" del teclado numerico por si tienes el celular cerca del teclado emitira luces asi >>> Ver link
http://www.crazypc.com/images/inputdevices/logisys/kb801/KB801.mpg
NOTA: ALGUIEN SABE DONDE ENCUENTRO UNO DE ESOS AKI EN EL SALVADOR?
Desconectado LicH
    • Sv Community
« Respuesta #2 : agosto 25, 2006, 12:32:17 pm »
sera dificil encontrar uno de esos man, aqui en El Salvador, solo venden esos teclados con la ruedita del volumen en el centro :p
Desconectado NoeL
    • SvCommunity
« Respuesta #3 : agosto 25, 2006, 12:41:57 pm »
bien dificil que lo hayes man, mejor mira si algun chero te hace el paro de comprartelo en linea y que te lo envien claro saldria un poco mas caro ;)
Desconectado netss
  • Net$$...
« Respuesta #4 : agosto 25, 2006, 05:25:01 pm »
Mmm.. y que tan factible seria si te fabricaras uno???
Aca eh visto que venden de los transparentes o semitransparentes, que hasta se enrollan, solo faltaria que le pusieras led's estrategicamente y listo.. tienes tu tecladito con luz...
LENNINX
« Respuesta #5 : agosto 25, 2006, 05:42:44 pm »
Mira amigo para comenzar esas ondas son caras aquì pero son super plantosas y duran te dejo el link del producto especifico que voz queres yo creo que es el mismo. Chequea la direcciòn porque hay tiendas en el paìs no necesitas comprar por internet te dejo el link.
http://www.compuaccesorios.com/shop/product_information.php?product=239&title=171939%20Teclado%20Multimedia%20Luminoso%20USB
« Última Modificación: agosto 25, 2006, 05:48:15 pm por LENNINX »
Desconectado netss
  • Net$$...
« Respuesta #6 : agosto 25, 2006, 08:06:19 pm »
Uta.. para 77$ creo que esta mejor tratar de hacerlo uno..  :phew:
Desconectado Jarthur
  • SVC Old Member.
« Respuesta #7 : agosto 25, 2006, 08:48:19 pm »
vaya esto si que es provechoso, otro gasto, pero que teclado.
lo que menos me esparaba es compuaccesorios lo trajera.
Tech Chat SV Community.
Desconectado JaiMe
  • λ | h+
« Respuesta #8 : agosto 25, 2006, 09:50:12 pm »
$77? que hijos de p***
los teclados sunbeantech no tienen muy buenas reviews, pero aun asi compre uno hace unos meses por que se ven "plantosos", el punto es que me ha funcionado bien y sin ningun problema grave. El unico pequeño inconveniente que tuve fue que las teclas direccionales estaban bien duras al principio. Y solo gaste $15!
Aqui hay uno parecido a $11.50, solo que la luz es verde.
http://www.newegg.com/Product/Product.asp?Item=N82E16823178109
― Ralph Waldo Emerson
LENNINX
« Respuesta #9 : agosto 25, 2006, 11:45:27 pm »
Es caro para un teclado pero dicen que duran bastante dependiendo del uso y trato. Yo en lo personal si me sobrara el dinero me compro uno, pero eh visto unos Benq que valen $20 super pequeños esos me gustan. Aunque si alguien vende uno de esos en ganga lo compro.
Desconectado netss
  • Net$$...
« Respuesta #10 : agosto 26, 2006, 09:32:51 am »
Hey jaime estan bonitos y accesibles esos teclados...
Esos seguramente los mandaste a traer.. o los compraste aca  :roll:
por lo del review que si son malos o buenos..
arreglar el teclado no tiene mucha complejidad..  :wacko: ya eh arreglado varios que estaban apunto de irse a la huesera
  • HACKSTAR ®
    • COMPRANDO BARATO
« Respuesta #11 : agosto 27, 2006, 01:39:20 am »
 :thumbsup: Gracias a todos por opinar  :thumbsup:
Weno ahi los q puse yo estan a 17 y a 20 con tax vienen saliendo como a 25 creo q esta bien no creen uta vere kien de mis amigos me hace el paro de mandarmelo... la idea de hacer una la ayo cañon pq la electronica no mucho prefiero el mantenimiento de pc q es cables y todo pero la mera electronica no mucho asi q kiza vere kien me hace el paro de comprarmelo, si alguien ve uno de esos en el pais mandeme un MP please, de ante mano gracias...
Nuevamente gracias por haber opinado amigos  :drinks:
  • HACKSTAR ®
    • COMPRANDO BARATO
« Respuesta #12 : agosto 27, 2006, 01:42:11 am »
Uta esta pag
la cheke gracias al bro ahi q la puso, uta q caros no mamen esos cabrones... weno mejor veo como hago pa q me la manden pero 77 ahahahahhaha no mamen tan  :dumb:
  • HACKSTAR ®
    • COMPRANDO BARATO
« Respuesta #13 : septiembre 04, 2006, 07:34:00 am »
Hey awebo ni modo vere kien viene dentro de poco pa decirle q me haga el paro pq uta ese de 77 varos esta cañon
« Última Modificación: septiembre 04, 2006, 07:37:05 am por hackstar »
Desconectado Ra!
Re: Teclado Con Luz (Donde hay de esos? aki en E.S.)
« Respuesta #14 : septiembre 04, 2006, 07:39:28 am »
esta chivo esa onda!! me ayudaria en las noches de trabajo!!! bua buscarlo y le bua decir a un chero que estudia aya ue me lo traiaga pa cuando salga de vacas si lo encuentro barato  :embarassed: Gracias por el aporte :p
"Solo una cosa vuelve un sueño imposible, el miedo a fracasar"
