How to download torrent file using utorrent + ultrasurf or uttorrent + TORThis is all about downloading uttorrent using ultrasurf and tor++ i created this because some of forums has a topic and i read their topic and i seems that they did not solve it just dont now in other forum but i experience this and it is working just fallow this the steeps.Screen shot of ultrasurf utorrent and tor++.In this tutorials lets assume that you already have ultrasurf,tor++ and utorrent v2.2.1 and let assume that you already know how to use ultrasurf and tor++ if not just google for it.Utorrent setting Click option menu select preferences.Under preferences window select connectionfor utorrent + TOR userProxy Server type: Socks5Proxy: 127.0.0.1Port: 9050for utorrent + Ultrasurf userProxy server type: HTTPProxy: 127.0.0.1Port: 9666Note: If you are using ultrasurf + utorrent the progress bar of utorrent will never change until it finished to download the file and it will automatically remove from downloading status and go to completed download.I already tested this just try to download small file and many seeders and leechers just to test if this is working or not.Any comments,feedback,question you are welcome to post it.
Cuál es la idea o el fin de usar ultrasurf para descargar un torrent?
Me imagino que esta bajo proxy y es por eso que se anda rebuscando conectar el Utorrent con UltraSurf ...
