Author Topic: I-MATE JAMIN (no es un Cd de mùsica)  (Read 1638 times)
LENNINX
« on: September 14, 2006, 07:54:07 pm »
I-MATE JAMIN
Qty: Price: $604.99
The i-mate JAMin is the supurb upgrade to the ever popular i-mate JAM. At last a device to meet all our wireless aspirations at the speed our busy lives require. Its features bring you the ultimate single solution to the communications and entertainment needs of the modern day. The JAMin is the same size as the JAM and JAM 128MB
The i-mate JAMin is Quad-band GSM, GPRS and has EDGEand Bluetooth. Its Wi-Fi capabilities are dual support (802.11b and 802.11g). The operating system is the latest Windows Mobile 5 software which includes standard packages such as Pocket Outlook, Phone, Internet Explorer, Power point, MSN Messenger and Games. With a healthy 128MB RAM and ROM, MMC/SDIO slot and 2 Megapixel digital camera slot the i-mate JAMin is packed with full customisable features, as well as being incredibly stylish and easy to use.
Features
Platform
• PDA form factor
• Microsoft Windows Mobile 5.0 Pocket PC Phone Edition
Dimension
• 108 mm(L) x 58 mm(W) x 18.2 mm(T)
• 150 g with battery pack
Processor/Chipset
• CPU: TI OMAP 850 200MHz
Memory
• ROM: 128 MB
• RAM: 64 MB
LCD Module
• 2.8” 240 x 320 dots resolution
• 64K-color TFT TransflectiveLCDwithwhiteLEDbacklight
• Sensitive Touch Screen
GSM/EDGE Function
• Internal antenna
• Quad-band (850/900/1800/1900)
• Audio codec: AMR, EFR, FR, HR
• SMS (MO, MT), concatenated SMS (640 characters)
• Supplement services:
Call holding/waiting/forwarding
Call barring
CLI (Calling Line Identity)
Display own number
Network selection
Cell broadcast
Multi-party conference call
Spool icon
Phase 2+ unstructured supplementary service data
Network Lock
• EDGE Functionality
EGPRS class B
Multi-slot class 10
PBCCH
Incremental redundancy
• SIM
3V operation
SIM Application Tool Kit release 98 class 3
Over the Air (OTA) programming
FDN
ADN
SDN
Security Pin 1 & 2 control
Stylus
• Lock type mechanism
Camera
• CMOS 2 Mega pixel with macro
• Preview Mirror
Keyboard/Button
• Power button
• One navigation pad (5-way)
• Send/Hands-free button
• End button
• Comm. manager/voice record (long press)
• Volume up & down
• Camera capture
• 2 AP buttons (Start-left button, OK-right button)
• 2 soft keys
• Reset
Notification
• One bi-color LED for GSM standby, GSM message, GSM
network status, notification, and charging status
• Two respective (blue and green) LEDs for
bluetooth/WiFi notification
• Vibration for notification
• Notificationbysoundandmessageonthedisplay
Audio
• Built-in Microphone
• Receiver
• Dual speakers on both sides with stereo sound
• Loud speaker for Hands-Free supported
• Full duplex
• Audio sampling rate
16-bits with 8KHz, 11KHz, 22KHz, 44.1KHz
• AMR/AAC/WAV/WMA/MP3 codec
Interface
• Infrared IrDA SIR
• SDIO/MMC card slot
• External antenna connector
• 3V SIM card
• 2.5 Ø stereo audio jack
Power
• Battery
Removable and chargeable Lithium ion polymer battery,
1200mAh
• AC adaptor
AC input: 100 ~ 240V AC, 50/60 Hz
DC output: 5V and 1A
Device-to-Device Connectivity
• Bluetooth
V 2.0 supported without EDR
Class 2 transmit power
Supported profiles
• Co-exist with Wi-Fi
IEEE 802.11b/g/e*/i* compliant
Internal WLAN antenna
11, 5.5, 2, and 1 Mbps per channel, auto fallback for
extended range
• Infrared IrDA SIR
• Mini-USB
Pocket PC Phone Edition Applications
•Microsoft Outlook Mobile: Inbox, Contacts, Calendar, Tasks
• Microsoft Windows Media Player
• Microsoft MSN Messenger
• Microsoft Internet Explorer Mobile
• Microsoft ActiveSync
• Games
• Calculator
• Voice Notes
• Photo Caller ID
• Closed User Group
Value Added Applications
• Camera capture utility
• Camcorder (H.263 and MPEG4 encoder and decoder)
• Polyphonic MIDI Ringtone Engine
• Smart Dialer
• Phone Pad
• MMS with video clip support
• JAVA virtual machine (J2ME, CLDC1.1, MIDP 2.0)
• Voice command/voice dial
• Modem Link
• Comm. Manager
SAR
Este telefono es màs completo que una PC  :D tiene de todo un poco es como una ensalda triple que tiene de todo pollo, jamòn...  :D es broma solo le falta decir hola no me toques soy muy buena jejeje como que si fuera una mujer.
Offline Kiori
Re: I-MATE JAMIN (no es un Cd de mùsica)
« Reply #1 on: September 14, 2006, 08:00:20 pm »
Mucho gusto en conocerla doña I mate jamin ya me habian hablado un poco de usted  ;)
Offline naru-loco
« Reply #2 on: September 15, 2006, 12:49:43 pm »
Esta interesante, y si que esta completo, es mejor opcion q una laptop, lo unico es la memoria de 128mb, con todo lo que tiene con 1gb estaria realmente irresistible, pero aun asi megustaria tener uno
