Author Topic: firmware huawei y220  (Read 21130 times)
Offline .::Dj Xiom::.
  • .::DX Xiom::.
Re:firmware huawei y220
« Reply #15 on: June 01, 2014, 05:30:12 pm »
me sale E: signature verification failed update.zip is not correct instalation aborted
pero necesito el modelo completo amigo para poder ayudarte
WHATSAPP/CELL: 61049855
  • .::DX Xiom::.
« Reply #16 on: June 01, 2014, 05:41:55 pm »
vaya aqui esta la rom de tu y220
http://www.needrom.com/wp-content/uploads/2013/04/HUAWEI_Ascend_Y200_firmware(U8655-1,Android%202.3,V100R001C00B898,Normal,05011DGR).zip
  • .::DX Xiom::.
« Reply #17 on: June 01, 2014, 05:44:53 pm »
hey se me olvido man, aqui estan los pasos
Description
ROM HUAWEI Y220 – ROM Android 2.3.5
ROM Official HUAWEI Y220 Version: HUAWEI_Ascend_Y200_firmware(U8655-1,Android 2.3,V100R001C00B898,Normal,05011DGR)
ROM install :
Step one: Prepare an SD card, it is recommended to use Sandisk, Kingstone, or Kingmax, size is recommended that more than 1G.
Step Two: Formatting SD card (optional).
The step three: copy a large package path UPDATA.APP to the SD card dload UPDATA.APP.
Step four: Check the root directory of the SD card you dload UPDATA.APP.
Step 5: SD card into the phone is switched on in the main screen, press the Menu key, the system updates -> SD card upgrade -> confirm -> upgrade, backup data, select the backup data; upgrade.
Step Six: The upgrade process progress bar shows after the finish of the pending progress bar, the phone automatically restart.
or
Step Four: cell phone turned off, insert the SD card, while pressing the volume up button + volume down key switch button, the phone automatically enters the upgrade mode, and then begin the    upgrade in Figure
Step Five: After the progress bar to go full fixed, the phone will automatically restart If you do not manually remove the battery.
Offline kierkhy
« Reply #18 on: June 01, 2014, 06:06:40 pm »
es el y220-U05
  • .::DX Xiom::.
« Reply #19 on: June 01, 2014, 06:12:13 pm »
es el y220-U05
ya te respondi amigoo sirve para y200 hasta el 220
Offline kierkhy
« Reply #20 on: June 01, 2014, 06:43:19 pm »
intente y nada , pero muchas gracias por tu ayuda , ni modo 70 dolaares a la basura  :-/  :sur:  :cry:  x_x  :@ pero gracias amigo
Offline kierkhy
« Reply #21 on: June 01, 2014, 06:49:59 pm »
lo unico que se me ocurre que algun forero que tenga ese telefono extraiga el firmware y me lo pase .
  • .::DX Xiom::.
« Reply #22 on: June 01, 2014, 06:50:21 pm »
nombre no todo esta perdido, decile a un amigo tuyo que tenga uno igual y que haga un recovery y de ahi que te lo pase a vos
  • .::DX Xiom::.
« Reply #23 on: June 01, 2014, 06:54:10 pm »
amigo seguro que estassiguiendo bien el procedimiento ?o no sabes leeer en ingles XD
Offline kierkhy
« Reply #24 on: June 01, 2014, 07:07:28 pm »
si lo hice bien , pero nada , segun lei solo se puede con el firmware original , es un problema de software , y si puedo ingles un 50 % aparte puedo usar GOOGLE TRANSLATE
  • .::DX Xiom::.
« Reply #25 on: June 01, 2014, 08:23:58 pm »
hey man este si te tiene que funcionar pero segui las intrucciones al pie de la letra
descarga este http://www.mediafire.com/download/1q6st5n3bi1e47v/HUAWEI_Ascend_Y220_firmware%28U8655-1%2CAndroid+2.3%2CV100R001C00B898%2CNormal%2C05011DGR%29.zip
instalación de rom original
Preparar una tarjeta SD , se recomienda el uso de Sandisk , Kingstone o Kingmax , se recomienda que el tamaño más de 1yiga.
copiar el paquete UPDATA.APP a la tarjeta SD Dload UPDATA.APP .
apaga tu equipo
ya que aya apagado presiona volumen arriba y el boton de encender
cuando ilumine el logo suelta los botones
y entra ala opcion aply update from de sdcard con el boton de volumen presiona ligeramente
y entraras en la raiz de tu sd y busca en la carpeta que ayas puesto el archivo
lo seleccionas y le pones que si y empesara a intalar el nuevo firmaware
se reiniciara solo y listo
para los que dicen que tienen problemas que no les aparece updata app es por que aun no lo descomprimen
FUENTE: https://www.youtube.com/watch?v=-KMDP0qlhw4
« Last Edit: June 01, 2014, 08:26:30 pm by .::Dj Xiom::. »
Offline plunplan
« Reply #26 on: June 01, 2014, 10:08:22 pm »
SI es el recovery stock no lo va a dejar instalar nada. Estas un poco fregado la verdad. Lo que se me ocurre es buscar un recovery para ese modelo e instalarlo por adb y luego intentar flashear alguna ROM o esa stock que bajaste. Claro, no se como es el soporte para ese modelo especifico (no se si hay recoverys no oficiales siquiera)
Offline JED57
« Reply #27 on: June 01, 2014, 10:32:39 pm »
habra manera de ponerlo en modo de flasheo? digamos tendra huawei algo similar al odin?
Sent from my BlackBerry Runtime for Android Apps using Tapatalk 2
  • .::DX Xiom::.
« Reply #28 on: June 01, 2014, 10:46:48 pm »
no amigo ya busque, y no hay manera ni huawei support te da una solucion
al parecer si hay recoverys como el CMW, pero si lo hace mal ya se pacio por completo en el telefono   :trollface:
  • .::DX Xiom::.
« Reply #29 on: June 01, 2014, 10:47:41 pm »
apaga tu equipo
