Author Topic: SmartMovie Converter & Player for Symbian Phones 3.0  (Read 2254 times)
Offline THUGLIFE
« on: February 08, 2006, 08:47:17 am »
SmartMovie is a video player for your mobile device, with counterpart PC converter utility. With the converter, you may prepare any video clip for playback on your mobile device.
Play your videos on your mobile device, anywhere, anytime, you need just a few steps:
Convert any video file on your PC into a phone-friendly video file
Upload video into device/memory card
Play the video in SmartMovie Player installed on your mobile device
Features:
Standard AVI format, allowing you to preview converted files on your PC.
Uses downloadable video codecs, allowing you to compress and play back videos in your favorite format.
Player uses the phone screen in portrait or landscape mode, utilizing the full screen size of the device.
Rescaling of video to utilize full-screen area.
PC converter allows you to split video file into multiple segments, so that it fits onto your memory card, if not entire, then cut to more parts - you may watch your favorite video in parts, e.g. while traveling to work/school.
First mobile player which supports subtitles - allowing you to watch movies in different languages.
Friendly PC converter - preview videos on PC, select parts you want to convert, alter quality.
Supports DirectShow codecs, so you may use video codecs downloadable from the internet.
Very fast conversion; on standard PC conversion is 5x faster than video clip playback time. You'll convert entire movie in just a few minutes
Bicubic rescale algorithm shrinks video to small screen size in best possible quality.
Adjustable quality parameters for video and audio streams, allowing tuning target video to your needs.
Customizable video Player (brightness, audio sync, volume, and more).
300 KB for SmartMovie player on the mobile device
PC with Windows 98/ME/2000/XP
Download
Code: [Select]
http://rapidshare.de/files/12683624/smartmovie_converter_3.rar.html
Mirror
http://www.megaupload.com/?d=RGTLK7F6
