Author Topic: Instalacion de Cursor en Windows  (Read 3681 times)
Offline EleCMaNn
« on: February 15, 2007, 11:02:56 pm »
Hey amigos por ahi me encontre unos cursores muy bonitoz y pues no se como ponerlos en Windows, Trae un txt de instalacion pero eso no me ayuda mucho.... Bueno aqui les dejo lo que trae al interior de el y pues a lo mejor me dicen como es la cosa, 0k.... Gracias  :thumbsup:
; xFree cursors for Windows XP.
; Win 2000/XP Alphablended Cursor Scheme installation file.
[Version]
signature="$CHICAGO$"
[DefaultInstall]
CopyFiles = Scheme.Cur, Scheme.Txt
AddReg    = Scheme.Reg
[DestinationDirs]
Scheme.Cur = 10,"%CUR_DIR%"
Scheme.Txt = 10,"%CUR_DIR%"
[Scheme.Reg]
HKCU,"Control Panel\Cursors\Schemes","%SCHEME_NAME%",,"%10%\%CUR_DIR%\%pointer%,%10%\%CUR_DIR%\%help%,%10%\%CUR_DIR%\%work%,%10%\%CUR_DIR%\%busy%,%10%\%CUR_DIR%\%cross%,%10%\%CUR_DIR%\%Text%,%10%\%CUR_DIR%\%Hand%,%10%\%CUR_DIR%\%unavailiable%,%10%\%CUR_DIR%\%Vert%,%10%\%CUR_DIR%\%Horz%,%10%\%CUR_DIR%\%Dgn1%,%10%\%CUR_DIR%\%Dgn2%,%10%\%CUR_DIR%\%move%,%10%\%CUR_DIR%\%alternate%,%10%\%CUR_DIR%\%link%"
; -- Common Information
[Scheme.Cur]
Normal Select.cur
Help Select.cur
Working In Background.ani
Busy.ani
Text Select.cur
Unavailable.cur
Vertical Resize.cur
Horizontal Resize.cur
Diagonal Resize 1.cur
Diagonal Resize 2.cur
Move.cur
Link Select.cur
Precision Select.cur
Handwriting.cur
Alternate Select.cur
[Strings]
CUR_DIR       = "Cursors\xFree Cursors"
SCHEME_NAME   = "xFree Cursors (Alphablended)"
pointer       = "Normal Select.cur"
help          = "Help Select.cur"
work          = "Working In Background.ani"
busy          = "Busy.ani"
text          = "Text Select.cur"
unavailiable  = "Unavailable.cur"
vert          = "Vertical Resize.cur"
horz          = "Horizontal Resize.cur"
dgn1          = "Diagonal Resize 1.cur"
dgn2          = "Diagonal Resize 2.cur"
move          = "Move.cur"
link          = "Link Select.cur"
cross         = "Precision Select.cur"
hand          = "Handwriting.cur"
alternate     = "Alternate Select.cur"
Offline Fatality
Re: Instalacion de Cursor en Windows
« Reply #1 on: February 15, 2007, 11:08:21 pm »
pone adonde los encontraste no hay q ser egoista :rofl: aunqeu no se como ayudarte :embarassed:
Offline Magneto
  • Sv Vampire Team ® Founder
  • Magnus
« Reply #2 on: February 16, 2007, 11:41:08 am »
yo le puesto uno bien chivo que se ve como que es el del vista pero esta bien bonito XD si lo quieren ahi se los dejo como adjunto a y es bien facil de instalar solo lean el readme .... =P
Pd: Quiero ShoutBox ¬¬
Offline Ronnie
  • -: Larga vida al rock :-
« Reply #3 on: February 17, 2007, 11:22:25 am »
Lo unico que tenes que hacer es cambiar la extencion de .txt por .inf.
Le das click derecho y seleccionas la opcion instalar y listo. :)
Offline ulises_lazo
    • http://www.aeroman.com.sv
« Reply #4 on: February 17, 2007, 12:10:41 pm »
man postea los iconos k tenes para la mara
Offline EleCMaNn
« Reply #5 on: February 17, 2007, 10:13:16 pm »
Bueno aqui los cursores, Son los de Ubuntu, Espero les guste  :thumbsup:
Offline Magneto
  • Magnus
« Reply #6 on: February 18, 2007, 04:31:58 am »
hey elecman ta chivo ese del umbutu gracias ois
Offline Tuker
  • arriero somos y en el camino andamos
« Reply #7 on: February 18, 2007, 07:19:57 am »
bueno gracias a probar voy a cer ue ondas  :thumbsup: :thumbsup:
Offline Tuker
« Reply #8 on: February 18, 2007, 07:28:39 am »
esta chivo man gacias  :thumbsup: :thumbsup:
