Hola. Me tope con esta útil herramienta (AMD Dual Core Optimizer) y tambien hay otras herramientas, pruebenlas: (Copy/Paste OBVIO Y SHUCO):
AMD Dual-Core Optimizer - The AMD Dual-Core Optimizer can help improve some PC
gaming video performance by compensating for those applications that bypass the
Windows API for timing by directly using the RDTSC (Read Time Stamp Counter)
instruction. Applications that rely on RDTSC do not benefit from the logic in the operating
system to properly account for the affect of power management mechanisms on the rate
at which a processor core's Time Stamp Counter (TSC) is incremented. The AMD Dual-Core
Optimizer helps to correct the resulting video performance effects or other incorrect timing
effects that these applications may experience on dual-core processor systems, by periodically adjusting the core time-stamp-counters, so that they are synchronized.
Download Now! August 2007
http://www.amd.com/us-en/Processors/TechnicalResources/0,,30_182_871_9706,00.html
