Author Topic: HOWTO Change guidows XP Home to guidows XP Pro  (Read 4477 times)
Offline LicH
    • Sv Community
« on: June 01, 2005, 04:39:48 pm »
Transformar Windows XP Home a Professional tan solo cuesta cambiar un par de Bytes.
Está circulando por Internet un documento "HOWTO Change Windows XP Home to Windows XP Pro" que facilita en forma de cómodos pasos como convertir Windows XP Home en Windows XP Pro, con tan sólo cambiar 2 bytes
filed under Software
We can’t vouch for this hack, because we are too lazy to try it (and we never, ever violate copyrights or EULAs), but kind reader Martin explains the process for turning an guidows XP Home install disc to a guidows XP Pro disc after the jump.
It sounds pretty simple to do (just some registry changes), but you can’t install Service Pack 2, so you might try to slipstream in the changes to your modified install disc (if that’s even possible).
Alternately, buy XP Pro, or get a Mac.
    yes indeed, you can’t change an installed guidows but only your Installation CD (or even a recovery CD in case the manufacturer had not left out important parts)
    Here’s the detailed breakdown you asked for.
    1. Copy the root directory and the i386 directory of the WindowsXP CD
    to your harddisk
    2. Extract the Bootsector of your WindowsXP CD
    3. Change 2 Bytes in i386\Setupreg.hiv :
    a) Open Regedit
    b) Highlight HKEY_LOCAL_MACHINE
    c) Menu: File -> Load Structure -> i386\Setupreg.hiv
    d) Assign an arbitrary name to the imported structure e.g. “Homekey”
    e) Goto HKEY_LOCAL_MACHINE\Homekey\ControlSet001\Services\setupdd
    f) edit the binary key “default” and change “01” to “00” and “02” to
    “00”
    g) Highlight “Homekey” and select menu: File -> unload structure
    4. Burn your new XP Pro CD
    5. Install WindowsXP as usual. Your XP Home Key will work.
    Note: You cannot apply SP2 to such a WindowsXP Pro, so step 1.b)
    might be to integrate SP2 in your Installation CD
    Please check the menu-entries as I don’t owe an English copy of
    XP and have to guess them.
Offline Tio B
Re: HOWTO Change guidows XP Home to guidows XP Pro
« Reply #1 on: June 01, 2005, 04:48:35 pm »
es como una version de nero,
la misma instalacion puede convertirse en basic o ultra
Offline NoeL
    • SvCommunity
« Reply #2 on: June 01, 2005, 04:51:04 pm »
Hey esta bueno este truco...apuntando...gracias se agradece el aporte.... :thumbsup:
