Author Topic: [AYUDA]BIOS PSWD Reseter ?  (Read 4641 times)
Offline H-LER
    • SV-Downloads
« on: May 23, 2011, 11:45:19 am »
<.Hola Communiters.
Tengo un problema con una Laptop , un cipote configurando un equipo nuevo le configuro la contraseña de BIOS incorrecta al sistema y creo que por la culiyera no se acuerda cual es ...
la laptop es una HP 8440p (WN014LA) ...
- Hirens no me funciono
- Quitarle la pila no funciono
- No le vi ningun Jumper como en las Pc's
- Los de soporte HP no cuentan con Contraseñas BackDoors  x_x  ( solo dell se q si )
- Busque algunos reseters pero no son compatibles con esta BIOS
Alguien sabe de una forma de resetear la BIOS .... gracias de antemano , Saludos !  :drinks:  .>
Offline ENIGMAXG2
Re: [AYUDA]BIOS PSWD Reseter ?
« Reply #1 on: May 23, 2011, 11:48:23 am »
¿Flashear BIOS? (ya sea actualizada -si la hay- o la misma versión que tenés) generalmente en el programa trae la opción "clear CMOS"
Offline G1r3D
« Reply #2 on: May 23, 2011, 11:54:43 am »
<.Hola Communiters.
Actualizando BIOS?
Code: [Select]
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01056794&lang=es&cc=es&taskId=101&contentType=SupportFAQ&prodSeriesId=4095872&prodTypeId=321957
Types of BIOS updates
The BIOS system can be updated with a process called 'flashing.' There are different types of flashing utilities; however, they all accomplish the same thing. Close all other programs before trying to flash the BIOS.
Winflash or HPQFlash is the most commonly used process. Download the file to the hard drive, and double-click the file to start the flash. Read and follow the instructions to complete the flash. Do not use the PC until the flash is complete and the PC has been restarted.
ROM Image is used by companies when they need to update many PCs at the same time. Download the file to the place on the network, then access the file from each PC.
ROMPaq involves restarting the PC with a bootable disc, CD, or USB key. Download the file to the hard drive, and double-click the file to create a bootable disc. Insert the bootable disk and restart the PC to flash the BIOS during the startup.
« Last Edit: May 23, 2011, 11:57:37 am by G1r3D »
Sintiendo una atracción
Offline H-LER
    • SV-Downloads
« Reply #3 on: May 23, 2011, 11:55:57 am »
Actualizando BIOS?
Code: [Select]
<.me pide la contraseña de BIOS para hacerlo  :phew: .>
Offline G1r3D
« Reply #4 on: May 23, 2011, 12:10:04 pm »
Leete esto:
Code: [Select]
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=130&prodSeriesId=3688868&prodTypeId=321957&prodSeriesId=3688868&objectID=c00719433
Code: [Select]
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c01798858&jumpid=reg_R1002_USEN
Code: [Select]
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c02745864/c02745864.pdf
Hay una onda que se llama Sparekey, si no estaba activado/configurado o se les olvido esos datos esta yuca para resetear viejo  x_x
Offline .::Dj Xiom::.
  • .::DX Xiom::.
« Reply #5 on: May 23, 2011, 12:18:35 pm »
 :shock: damnnnnn it esta cabron !!!
WHATSAPP/CELL: 61049855
Offline Lugaid
  • his name is Linux
« Reply #6 on: May 23, 2011, 12:18:49 pm »
la laptop carga windows o te pide la clave para iniciar?
Offline G1r3D
« Reply #7 on: May 23, 2011, 12:29:25 pm »
Pues por lo que dijo el H-LER es nada mas la BIOS, porque si le carga el SO.
Solo que le quiere cambiar alguna configuracion...
... y no se recuerda que le puso el nombre de su primera mascota XD
Bueno al menos asi le he entendido yo...  :roll:
Offline Jarmandaros
  • -^- Despicable Member -^-
    • Jarmandaros Blog
« Reply #8 on: May 23, 2011, 12:30:06 pm »
las HP creo que utilizan la BIOS de Phoenix  :roll:
ya probaste?
Phoenix Backdoor BIOS Passwords:
BIOS
CMOS
phoenix
PHOENIX
por cuanto tiempo le quitaste la pila?
[youtube]http://www.youtube.com/watch?v=D72M6wpEhZE[/youtube]
Using MS DOS Command:
This method works only if you have access to the system when its turned on because this method requires MS DOS. Open Command Prompt from Programs menu and provide following commands one bye one:
debug
o 70 2E
o 71 FF
quit
NOTE: The first character in the above commands is English alphabet "o" and not the number 0.
After providing the above commands, restart your system and it should reset the CMOS Settings along with the BIOS password.
If you are curious to know how it works? then let me explain the above commands:
In this method we are using the Debug tool of MS DOS. The "o" character present at first in these commands, outputs the values to IO ports. The number 70 and 71 are port numbers which are used to access CMOS memory. By providing FF value we are telling CMOS that there is an invalid checksum and it resets the CMOS settings as well as BIOS password.
Visita mi Blog
Offline H-LER
    • SV-Downloads
« Reply #9 on: May 23, 2011, 12:31:10 pm »
<.carga ...
Quiero entrar a configurar la BIOS ...  por ejemplo para activar los controladores Satas  x_x
no es que este bloqueada de arranque.
ahorita toy viendo los documentos que me dejo el chiricuto de G!r3D ... .>
Offline Jarmandaros
    • Jarmandaros Blog
« Reply #10 on: May 23, 2011, 12:32:45 pm »
proba este soft tambien
Code: [Select]
http://www.pccmos.com/
Visita mi Blog
Offline H-LER
    • SV-Downloads
« Reply #11 on: May 23, 2011, 12:33:40 pm »
ya probaste?
BIOS
CMOS
phoenix
PHOENIX
<.Pues mi intencion era quitarsela por 30 mins, pero la desesperacion creo q me gano a los 15mins  :rofl:
y en esta maquina (quizas por nueva) no identifica que BIOS trae , ya habia visto esa Herramienta pero no la e usado aun ... despues de ver las letras que me dejo GIRED pruebo ..
Gracias por el interes .. !  :drinks: .>
